zabbix database format
  • dave08
    • Jan 2020
    • 29
    Hello.
    I'm using a zabbix 5.4.6 appliance and had been updating the database since previous versions. In the Dashboard I get: "Unsupported charset or collation for tables: dashboard_page, httptest_tag, item_tag, report, report_param, script_param, sysmaps_element_tag, token, valuemap, valuemap_mapping." even after entered the following command:
    "alter database zabbix character set utf8 collate utf8_bin;"
    Now my database list character_set_database is utf8mb3 (Instead of utf8mb4) and utfb8_bin as collation_database instead of previous "utf8mb4_0900_ai_ci";
    Why do I get the error in the dashboard and why can't I set the character_set_database to utf8 instead of utfbmb3?
    Thank you so much!
    Regards
    David
  • Answer selected by dave08 at 12-01-2022, 16:00.
    dimir
    Zabbix developer
    • Apr 2011
    • 1080
    You need to alter the tables explicitly:
    alter table dashboard_page convert to character set utf8 collate utf8_bin;
    and others.
    • dimir
      Zabbix developer
      • Apr 2011
      • 1080
      and others.
      • dave08
        • Jan 2020
        • 29
        Thanks for the reply. No more alerts.
        Hi hope I won't have any issues by cannot change the character_set_databse to utf8 instead of utf8mb3.
