Trigger executing falsely even when values do not meet threshold| v3.4
  • kapabhi
    • Jan 2022
    Hi ,
    I have setup trigger in zabbix with trigger and recovery condition as below:
    Trigger Condition:
    ({SUBMITTED_TASK_COUNT.last(#1)} - {COMPLETED_TASK_COUNT.last(#1)})>10 and ({SUBMITTED_TASK_COUNT.last(#2)} - {COMPLETED_TASK_COUNT.last(#2)})>10
    Recovery Condition:
    ({SUBMITTED_TASK_COUNT.last(#1)} - {COMPLETED_TASK_COUNT.last(#1)})<5 and ({SUBMITTED_TASK_COUNT.last(#2)} - {COMPLETED_TASK_COUNT.last(#2)})<5
    Last 2 Values:
    SUBMITTED_TASK_COUNT : 128.6 & 143.9
    COMPLETED_TASK_COUNT : 128.6 & 143.9
    Problem Statement: Trigger and Recovery condition is validated as TRUE at the same time and and it triggers and resolved with 0 second duration. (Both values are fed by a script and recorded via Zabbix trapper and then post-processed as 'change in second')
    Any help will be greatly appreciated.
  • ISiroshtan
    • Nov 2019
    • 324
    Hey mate.
    If both Trigger and Recovery evaluate True - trigger remain in problem state. Recovery expression evaluated only AFTER trigger expression evaluated FALSE.
    Most probable cause of issue here is the fact that trigger re-evaluates after ANY of it's condition item is updated. And data for items comes with minimal but still a time difference, causing 2 evaluations of trigger. For example:
    Time: 00:00:00
    Time: 00:01:00.000
    New data pulled:
    SUBMITTED_TASK_COUNT : 143.9
    143 - 128 = 15 > 10 - open trigger
    Time: 00:01:00.010
    New data pulled:
    COMPLETED_TASK_COUNT : 143.9
    143-143 = 0 < 10 ---Evaluate recovery--> 0 < 5 --> close the trigger
    Effective time trigger was up - 00:00:00.010
    As an option to solve it:
    If it it's tolerable to delay Alert raising by one extra pull cycle, try adding <time_shift> to last() functions. Like 5 seconds.
    This will mean when new data arrives it evaluates values that were 5 seconds back in time, removing time discrepancy introduced by data arriving lag in exchange for delayed Trigger firing.
    Alternatively - create a calculated item where perform comparison of SUBMITTED_TASK_COUNT and COMPLETED_TASK_COUNT, and use this delta item in trigger. Calculated items run on it's own set timer so should not be affected by data arrive lag.
    Hope it helps mate.
