rhel8 selinux ssh.run with ssh keys keeps failing
  • Alex_SYB
    • Feb 2012
    • 133
    Hi
    I have rhel8 box with zabbix 5.4 installed. Working nicely
    I am trying to use router BGP json template.
    which uses ssh.run
    I have made a slight change to it to use ssh keys.
    I have set the ssh key location in zabbix server config
    and when i am in permissive mode it works.
    when i turn it on to enforcing it fails
    I tried
    # made sure to log do not log
    semodule -DB
    ausearch -ts recent | audit2allow -D -M zabbix-fix
    and then loading the module (i did it in permissive mode so it should capture all of the warnings)
    it doesn't work
    I'm at a loss.
    zabbix home
    /home/zabbix
    ssh -> /home/zabbix/.ssh
    drwx------. 2 zabbix zabbix unconfined_ubject_r:ssh_home_t:s0 77 Jan 13 18:17 .ssh
    drwxr-xr-x. 3 zabbix zabbix unconfined_ubject_r:user_home_dir_t:s0 181 Jan 13 19:12 .
    I have to run it in permissive mode - which i don't want to do .. but i can't seem to find the issue
    I think .. is the contect for .ssh
    user_home_dir_t is for /home/zabbix and audit2allow always references it !
    bit .ssh is ssh_home_t
    the error from zabbix - test item is can not access <file name>
    when i turn into the user I can access the file
