LLD Discovery needs to be able to return MACRO that may contain an "@" symbol
  • MrClayPole
    • Oct 2021
    I have an LLD discovery rule that sometimes returns values that contains "@" symbol as part of the JSON. example below
    "Binary": "cinder-volume",
    "Host": "servername@storage",
    "Zone": "default",
    "Status": "enabled",
    "State": "up",
    "Updated At": "2022-01-13T11:49:56.000000"
    Is there any way to escape the "@" symbol so it can be used in item prototypes as I'm currently getting 'Character "@" is not allowed'?
  • Answer selected by MrClayPole at 14-01-2022, 11:45.
    MrClayPole
    • Oct 2021
    Fixed it. I needed to set "UnsafeUserParameters" to "1" in Zabbix agent conf and restart the agent.
    • MrClayPole
      • Oct 2021
        • 4970
        Intresting... "UnsafeUserParameters" has nothing to do with LLD.. (Allow all characters to be passed in arguments to user-defined parameters).
        Only in case, when your items, created by discovery, are using userparameters...
        • MrClayPole
          • Oct 2021
          Hi, I can see my initial description was not 100% clear. The LLD discovery creates the items correctly but they then fail with above error as when they attempt to run against zabbix agent
