Good day.
Help pliz in settings zabiks.
We have a Windows server with 2 network cards. One looks at the LAN, the other looks at the remote LAN. How can I set up a ping check to devices, it is from this server on the second card. The device availability check can only be performed via icmp.
Tried through the ismp ping template attached to this host, by adding through a group of elements, but in the agent section, only the first network can be selected. Zabbix itself collects data from the second network card. I tried to add the file to the config file in the ListenIP or SourceIP section to specify the IP of the network cards.
