Using Macros to configure Trigger with vfs.dir.count[{$PATHTODIR}
  • grodan
    • Jun 2020
    Is it possible to use a macro to define a global template for file count, changing the value per server group?
    vfs.dir.count[{$PATHTOFILE},,,,,0,,,,,].last()}>={$MAIL_NR}
    I need to use the macro to replace the DIR value depending of the server.
    Yes, you can have a macro in template but its value comes from host level.
