Hello.
Zabbix server version: 5.0.17
I'm trying to create a trigger through API, I put
in "expression" variable, but I always get
Invalid parameter "/1/expression": incorrect trigger expression starting from "last(/test-host/net.tcp.listen[443])=0
The same error is given if I try to put this string in "expression" field through web interface.
Even direct copy-paste from example for expression
gives the same error.
Please help
last(/Zabbix server/system.cpu.load[all,avg1])>5
Please help
