i am using vPoller with Zabbix. It is working great.
Did someone implement a guest disk usage?
Can i Monitor with vpoller the guest Disks.
I found this one, unfortunally i am stuck.
Update:
the vPoller Template "Template VMware vSphere Virtual Machine - vPoller Native" contains a discovery rule "Filesystem Discovery". that is exactly what i was looking for.
