How to set zabbix to delete old data
  • przemo2
    • Oct 2020
    • 23
    Friends, help me, zabbix has been with me for a year and has clogged the entire disk, how to delete old data and set zabbix so that it cleans data older than a month
Name:	Screen Shot 01-23-22 at 03.10 PM.png
  • KPiatek
    • Jan 2022
    You should find it under Administration -> General -> Housekeeping. Additionally, if you are using PostgreSQL you might want to think about TimescaleDB.
    • pala
      • Sep 2021
      Hi, in my case, I set a script in crontab in order to purge old data manually:
      DELETE FROM history WHERE clock < a date
      commit;
      analyze table history;
      DELETE FROM history_str WHERE clock < a date
      commit;
      analyze table history_str;
      DELETE FROM history_uint WHERE clock < a date
      commit;
      analyze table history_uint;
      #"REDO"
      PURGE BINARY LOGS BEFORE DATE_SUB( NOW( ), INTERVAL 7 DAY);
      In addition, I have a item to get everyday the database size.
      I got this from forums
      Regards
      • przemo2
        • Oct 2020
        • 23
        Hey buddy, it seems your commands are helpful because the above ones don't work. But I have such a problem with DELETE FROM history_uint
        I get such an error lock wait timeout exceeded try restarting transaction
        it helped just don't know what's the difference ...
        truncate table history;
        truncate table history_str;
        truncate table history_uint;
        truncate table trends;
        truncate table trends_uint;
        truncate table events;
        Can someone explain why it doesn't work?
        Database : MySQL
