Autoregistration not detecting new agents
  • LordGraves
    • Jan 2022
    • 17
    Hi all,
    Ive been going through this for the last couple days. Manually adding a new agent is pretty easy, but for some reason I just cannot get autoregister to work for me. I'm sure I am missing something simple.
    • Zabbix Server:
      • 5.0
    • Agent:
      • OS: RHEL 7
      • Agent: zabbix-agent-4.0.37-1.el7.x86_64
    • Agent Configuration:
      • On the client side, I have zabbix agent installed. In etc/zabbix, I have my psk file saved. The string within that file is added to my zabbix_agentd.conf, the contents of which are pasted below (settings bolded for easier reading. IPs, PSK strings, and Hostnames removed):
    # This is a configuration file for Zabbix agent daemon (Unix)
    # To get more information about Zabbix, visit http://www.zabbix.com
    ### Option: PidFile
    # Name of PID file.
    # Mandatory: no
    # Default:
    # PidFile=/tmp/zabbix_agentd.pid
    PidFile=/var/run/zabbix/zabbix_agentd.pid
    ### Option: LogType
    # Specifies where log messages are written to:
    # system - syslog
    # file - file specified with LogFile parameter
    # console - standard output
    # Mandatory: no
    # Default:
    # LogType=file
    ### Option: LogFile
    # Log file name for LogType 'file' parameter.
    # Mandatory: yes, if LogType is set to file, otherwise no
    # Default:
    # LogFile=
    LogFile=/var/log/zabbix/zabbix_agentd.log
    ### Option: LogFileSize
    # Maximum size of log file in MB.
    # 0 - disable automatic log rotation.
    # Mandatory: no
    # Range: 0-1024
    # Default:
    # LogFileSize=1
    LogFileSize=0
    ### Option: DebugLevel
    # Specifies debug level:
    # 0 - basic information about starting and stopping of Zabbix processes
    # 1 - critical information
    # 2 - error information
    # 3 - warnings
    # 4 - for debugging (produces lots of information)
    # 5 - extended debugging (produces even more information)
    # Mandatory: no
    # Range: 0-5
    # Default:
    # DebugLevel=3
    ### Option: SourceIP
    # Source IP address for outgoing connections.
    # Mandatory: no
    # Default:
    # SourceIP=
    ### Option: EnableRemoteCommands
    # Whether remote commands from Zabbix server are allowed.
    # 0 - not allowed
    # 1 - allowed
    # Mandatory: no
    # Default:
    # EnableRemoteCommands=0
    ### Option: LogRemoteCommands
    # Enable logging of executed shell commands as warnings.
    # 0 - disabled
    # 1 - enabled
    # Mandatory: no
    # Default:
    # LogRemoteCommands=0
    ##### Passive checks related
    ### Option: Server
    # List of comma delimited IP addresses, optionally in CIDR notation, or DNS names of Zabbix servers and Zabbix proxies.
    # Incoming connections will be accepted only from the hosts listed here.
    # If IPv6 support is enabled then '127.0.0.1', '::127.0.0.1', '::ffff:127.0.0.1' are treated equally
    # and '::/0' will allow any IPv4 or IPv6 address.
    # '0.0.0.0/0' can be used to allow any IPv4 address.
    # Example: Server=127.0.0.1,192.168.1.0/24,::1,2001:db8::/32,zabbix.example.com
    # Mandatory: yes, if StartAgents is not explicitly set to 0
    # Default:
    # Server=
    Server=127.0.0.1
    ### Option: ListenPort
    # Agent will listen on this port for connections from the server.
    # Mandatory: no
    # Range: 1024-32767
    # Default:
    # ListenPort=10050
    ### Option: ListenIP
    # List of comma delimited IP addresses that the agent should listen on.
    # First IP address is sent to Zabbix server if connecting to it to retrieve list of active checks.
    # Mandatory: no
    # Default:
    # ListenIP=0.0.0.0
    ### Option: StartAgents
    # Number of pre-forked instances of zabbix_agentd that process passive checks.
    # If set to 0, disables passive checks and the agent will not listen on any TCP port.
    # Mandatory: no
    # Range: 0-100
    # Default:
    # StartAgents=3
    ##### Active checks related
    ### Option: ServerActive
    # List of comma delimited IPort (or DNS nameort) pairs of Zabbix servers and Zabbix proxies for active checks.
    # If port is not specified, default port is used.
    # IPv6 addresses must be enclosed in square brackets if port for that host is specified.
    # If port is not specified, square brackets for IPv6 addresses are optional.
    # If this parameter is not specified, active checks are disabled.
    # Example: ServerActive=127.0.0.1:20051,zabbix.domain,[::1]:30051,::1,[12fc::1]
    # Mandatory: no
    # Default:
    # ServerActive=
    ServerActive=***Zabbix Server IP Goes Here***
    ### Option: Hostname
    # Unique, case sensitive hostname.
    # Required for active checks and must match hostname as configured on the server.
    # Value is acquired from HostnameItem if undefined.
    # Mandatory: no
    # Default:
    # Hostname=
    Hostname=zabbix.server
    ### Option: HostnameItem
    # Item used for generating Hostname if it is undefined. Ignored if Hostname is defined.
    # Does not support UserParameters or aliases.
    # Mandatory: no
    # Default:
    # HostnameItem=system.hostname
    ### Option: HostMetadata
    # Optional parameter that defines host metadata.
    # Host metadata is used at host auto-registration process.
    # An agent will issue an error and not start if the value is over limit of 255 characters.
    # If not defined, value will be acquired from HostMetadataItem.
    # Mandatory: no
    # Range: 0-255 characters
    # Default:
    # HostMetadata=
    ### Option: HostMetadataItem
    # Optional parameter that defines an item used for getting host metadata.
    # During an auto-registration request an agent will log a warning message if
    # the value returned by specified item is over limit of 255 characters.
    # This option is only used when HostMetadata is not defined.
    # Mandatory: no
    # Default:
    # HostMetadataItem=
    ### Option: RefreshActiveChecks
    # How often list of active checks is refreshed, in seconds.
    # Mandatory: no
    # Range: 60-3600
    # Default:
    # RefreshActiveChecks=120
    ### Option: BufferSend
    # Do not keep data longer than N seconds in buffer.
    # Mandatory: no
    # Range: 1-3600
    # Default:
    # BufferSend=5
    ### Option: BufferSize
    # Maximum number of values in a memory buffer. The agent will send
    # all collected data to Zabbix Server or Proxy if the buffer is full.
    # Mandatory: no
    # Range: 2-65535
    # Default:
    # BufferSize=100
    ### Option: MaxLinesPerSecond
    # Maximum number of new lines the agent will send per second to Zabbix Server
    # or Proxy processing 'log' and 'logrt' active checks.
    # The provided value will be overridden by the parameter 'maxlines',
    # provided in 'log' or 'logrt' item keys.
    # Mandatory: no
    # Range: 1-1000
    # Default:
    # MaxLinesPerSecond=20
    ############ ADVANCED PARAMETERS #################
    ### Option: Alias
    # Sets an alias for an item key. It can be used to substitute long and complex item key with a smaller and simpler one.
    # Multiple Alias parameters may be present. Multiple parameters with the same Alias key are not allowed.
    # Different Alias keys may reference the same item key.
    # For example, to retrieve the ID of user 'zabbix':
    # Alias=zabbix.userid:vfs.file.regexp[/etc/passwd,^zabbix:.[0-9]+),,,,\1]
    # Now shorthand key zabbix.userid may be used to retrieve data.
    # Aliases can be used in HostMetadataItem but not in HostnameItem parameters.
    # Mandatory: no
    # Range:
    # Default:
    ### Option: Timeout
    # Spend no more than Timeout seconds on processing
    # Mandatory: no
    # Range: 1-30
    # Default:
    # Timeout=3
    ### Option: AllowRoot
    # Allow the agent to run as 'root'. If disabled and the agent is started by 'root', the agent
    # will try to switch to the user specified by the User configuration option instead.
    # Has no effect if started under a regular user.
    # 0 - do not allow
    # 1 - allow
    # Mandatory: no
    # Default:
    # AllowRoot=0
    ### Option: User
    # Drop privileges to a specific, existing user on the system.
    # Only has effect if run as 'root' and AllowRoot is disabled.
    # Mandatory: no
    # Default:
    # User=zabbix
    ### Option: Include
    # You may include individual files or all files in a directory in the configuration file.
    # Installing Zabbix will create include directory in /usr/local/etc, unless modified during the compile time.
    # Mandatory: no
    # Default:
    # Include=
    Include=/etc/zabbix/zabbix_agentd.d/*.conf
    # Include=/usr/local/etc/zabbix_agentd.userparams.conf
    # Include=/usr/local/etc/zabbix_agentd.conf.d/
    # Include=/usr/local/etc/zabbix_agentd.conf.d/*.conf
    ### Option: UnsafeUserParameters
    # Allow all characters to be passed in arguments to user-defined parameters.
    # The following characters are not allowed:
    # Additionally, newline characters are not allowed.
    # 0 - do not allow
    # 1 - allow
    # Mandatory: no
    # Range: 0-1
    # Default:
    # UnsafeUserParameters=0
    ### Option: UserParameter
    # User-defined parameter to monitor. There can be several user-defined parameters.
    # Format: UserParameter=<key>,<shell command>
    # See 'zabbix_agentd' directory for examples.
    # Mandatory: no
    # Default:
    # UserParameter=
    ####### LOADABLE MODULES #######
    ### Option: LoadModulePath
    # Full path to location of agent modules.
    # Default depends on compilation options.
    # To see the default path run command "zabbix_agentd --help".
    # Mandatory: no
    # Default:
    # LoadModulePath=${libdir}/modules
    # Module to load at agent startup. Modules are used to extend functionality of the agent.
    # Formats:
    # LoadModule=<module.so>
    # LoadModule=<path/module.so>
    # LoadModule=</abs_path/module.so>
    # Either the module must be located in directory specified by LoadModulePath or the path must precede the module name.
    # If the preceding path is absolute (starts with '/') then LoadModulePath is ignored.
    # It is allowed to include multiple LoadModule parameters.
    # Mandatory: no
    # Default:
    # LoadModule=
    ####### TLS-RELATED PARAMETERS #######
    ### Option: TLSConnect
    # How the agent should connect to server or proxy. Used for active checks.
    # Only one value can be specified:
    # unencrypted - connect without encryption
    # psk - connect using TLS and a pre-shared key
    # cert - connect using TLS and a certificate
    # Mandatory: yes, if TLS certificate or PSK parameters are defined (even for 'unencrypted' connection)
    # Default:
    # TLSConnect=unencrypted
    TLSConnect=psk
    ### Option: TLSAccept
    # What incoming connections to accept.
    # Multiple values can be specified, separated by comma:
    # unencrypted - accept connections without encryption
    # psk - accept connections secured with TLS and a pre-shared key
    # cert - accept connections secured with TLS and a certificate
    # Default:
    # TLSAccept=unencrypted
    TLSAccept=psk
    ### Option: TLSCAFile
    # Full pathname of a file containing the top-level CA(s) certificates for
    # peer certificate verification.
    # Mandatory: no
    # Default:
    # TLSCAFile=
    ### Option: TLSCRLFile
    # Full pathname of a file containing revoked certificates.
    # Mandatory: no
    # Default:
    # TLSCRLFile=
    ### Option: TLSServerCertIssuer
    # Allowed server certificate issuer.
    # Mandatory: no
    # Default:
    # TLSServerCertIssuer=
    ### Option: TLSServerCertSubject
    # Allowed server certificate subject.
    # Mandatory: no
    # Default:
    # TLSServerCertSubject=
    ### Option: TLSCertFile
    # Full pathname of a file containing the agent certificate or certificate chain.
    # Mandatory: no
    # Default:
    # TLSCertFile=
    ### Option: TLSKeyFile
    # Full pathname of a file containing the agent private key.
    # Mandatory: no
    # Default:
    # TLSKeyFile=
    ### Option: TLSPSKIdentity
    # Unique, case sensitive string used to identify the pre-shared key.
    # Mandatory: no
    # Default:
    # TLSPSKIdentity=
    TLSPSKIdentity=***PSK File Text String Goes Here***
    ### Option: TLSPSKFile
    # Full pathname of a file containing the pre-shared key.
    # Mandatory: no
    # Default:
    # TLSPSKFile=
    TLSPSKFile=/etc/zabbix/secret.psk
    ####### For advanced users - TLS ciphersuite selection criteria #######
    ### Option: TLSCipherCert13
    # Cipher string for OpenSSL 1.1.1 or newer in TLS 1.3.
    # Override the default ciphersuite selection criteria for certificate-based encryption.
    # Mandatory: no
    # Default:
    # TLSCipherCert13=
    # GnuTLS priority string or OpenSSL (TLS 1.2) cipher string.
    # Example for GnuTLS:
    # NONE:+VERS-TLS1.2:+ECDHE-RSA:+RSA:+AES-128-GCM:+AES-128-CBC:+AEAD:+SHA256:+SHA1:+CURVE-ALL:+COMP-NULL:+SIGN-ALL:+CTYPE-X.509
    # Example for OpenSSL:
    # EECDH+aRSA+AES128:RSA+aRSA+AES128
    # Mandatory: no
    # Default:
    # TLSCipherCert=
    ### Option: TLSCipherPSK13
    # Override the default ciphersuite selection criteria for PSK-based encryption.
    # Example:
    # TLS_CHACHA20_POLY1305_SHA256:TLS_AES_128_GCM_SHA25 6
    # Mandatory: no
    # Default:
    # TLSCipherPSK13=
    # NONE:+VERS-TLS1.2:+ECDHE-PSK:+PSK:+AES-128-GCM:+AES-128-CBC:+AEAD:+SHA256:+SHA1:+CURVE-ALL:+COMP-NULL:+SIGN-ALL
    # kECDHEPSK+AES128:kPSK+AES128
    # Mandatory: no
    # Default:
    # TLSCipherPSK=
    ### Option: TLSCipherAll13
    # Override the default ciphersuite selection criteria for certificate- and PSK-based encryption.
    # Example:
    # TLS_AES_256_GCM_SHA384:TLS_CHACHA20_POLY1305_SHA25 6:TLS_AES_128_GCM_SHA256
    # Mandatory: no
    # Default:
    # TLSCipherAll13=
    # NONE:+VERS-TLS1.2:+ECDHE-RSA:+RSA:+ECDHE-PSK:+PSK:+AES-128-GCM:+AES-128-CBC:+AEAD:+SHA256:+SHA1:+CURVE-ALL:+COMP-NULL:+SIGN-ALL:+CTYPE-X.509
    # EECDH+aRSA+AES128:RSA+aRSA+AES128:kECDHEPSK+AES128 :kPSK+AES128
    # Mandatory: no
    # Default:
    # TLSCipherAll=
    • Frontend Conifguration:
      • Autoregistration Action created
        • Conditions: Host Name contains <hostname prefix>
        • Operations: Add to host groups: Discovered hosts, Linux Servers. Link to templates: Template OS Linux by Zabbix agent.
        • Status: Enabled
    • Administration
      • Under Autoregistration: PSK Encryption is enabled.
      • PSK Info
        • PSK Identity: Contains same secret phrase as TLSPSKIdentity in the agent config.
        • PSK: Contains the string from the secret.psk file in the zabbix directory of the client (agent) machine.
    • 5002
    Server=127.0.0.1 this should also point to your zabbix server or proxy not to localhost.
    Hostname=zabbix.server This should be your hosts name. Or commented, if you want to use HostnameItem. It will be used to identify your host in Zabbix. Must be unique.
    TLSPSKIdentity=***PSK File Text String Goes Here*** "The string within that file is added to my zabbix_agentd.conf" This should not be contents of the secret.psk file, but just the identity what you set under "Administration" -> general -> auto registration -> PSK...
    • LordGraves
      • Jan 2022
      • 17
      I have no idea how I managed to mess up TLSPSKidentity, I set the Server variable to the Zabbix Server IP, and commented out the Hostname variable. After restart the server popped up in my dashboard immediately. Thank you!
