docker and powershell libraries
  • alexciv
    • Aug 2018
    Dear Zabbix Community
    I use the docker zabbix-proxy-mysql but I have to run some script in powershell (i'm in a linux ubuntu environment)
    how can i add powershell libraries to docker proxy?
    thank you
  • rthonpm
    • Jan 2016
    • 44
    What does the PowerShell script do, and what does it monitor? You can install PowerShell in Ubuntu natively, but it sounds like your scripts expect something in Windows.
    Sent from my BBE100-5 using Tapatalk
    • alexciv
      • Aug 2018
      in powershell control of external services.
      I use powershell for linux because it is a language I know best.
      The proxy has to run these scripts but being in the docker it doesn't recognize the powershell libraries in the native ubuntu.
      I thought about creating a custom docker image
      • rthonpm
        • Jan 2016
        • 44
        That's likely going to be your best bet. I've generally only used PowerShell with Zabbix on Windows hosts to return rather simple data that correspond to a value mapping.
