Trigger Action do not show the "remote command" options
  • Zabbixtrator
    • Jan 2022
    Hi all,
    I'm trying the configuration a new trigger action. When editing operations steps I can not see the "remote command" step. I can chose only the "send message".
    But on the Zabbix 5.4 documents tell the us "remote-commands" we can run. I'm not sure where is the error. Is it strange or am I wrong?
  • ISiroshtan
    • Nov 2019
    • 324
    In version 5.4 you need to first create a script in Administration - Script with Scope "Action operation". After that you will be able to choose this script as operation in Action.
    Detailed info can be found in Remote Command documentation section Predefined scripts.
    Hope it helps mate.
    • Zabbixtrator
      Zabbixtrator commented
      Thank you so much ISiroshtan. It's done.
