NEWBIE Question Acknowledgement / problem question
  • snephew
    • Jan 2022
    I have setup the Zabbix Appliance all in all seems to be going great, so here is what I have been trying to figure out with our switch alerts that when a switch changes speeds / or goes down, we want to be alerted on it, however once acknowledged then we would like for that to drop off the problem list and not show back up until the status changes again.
    Here are a few of them :
    Interface 13(-): Link down
    Interface 1:21(Default settings for the trunk port): Link down)
    Interface 21(): In half-duplex mode
    So basically I want to suppress them on the problem/dashboard
    However, If I go in and close them within time they will pop right back up with the same status.
  • incama
    • Jan 2015
    • 66
    You can filter the acknowledge problems so they disappear. You can do that in the widget setting when using the dashboard, or the filter option in the problem section.
    • snephew
      snephew commented
      I honestly didnt even notice that... Thanks for pointing it out.
