How to filter SNMP Traps
  • rpittom
    • Sep 2015
    I'm not sure how to word this correctly but we have an SNMP Trap coming in from a central server which has many nodes. The message looks like this -
    HTML Code:
    13:04:50 2015/12/01 ZBXTRAP 10.78.12.115
    PDU INFO:
      notificationtype               TRAP
      version                        0
      receivedfrom                   UDP: [10.78.12.115]:61937->[10.78.12.6]
      errorstatus                    0
      messageid                      0
      community                      public
      transactionid                  820394
      errorindex                     0
      requestid                      0
    VARBINDS:
      DISMAN-EVENT-MIB::sysUpTimeInstance type=67 value=Timeticks: (13061229) 1 day, 12:16:52.29
      SNMPv2-MIB::snmpTrapOID.0      type=6  value=OID: SNMPv2-SMI::enterprises.1214.0.1
      SNMPv2-SMI::enterprises.1214.1.3 type=2  value=INTEGER: 1
      SNMPv2-SMI::enterprises.1214.1.4 type=2  value=INTEGER: 1
      SNMPv2-SMI::enterprises.1214.1.5 type=4  value=STRING: "values for testing"
      SNMPv2-SMI::enterprises.1214.1.6 type=2  value=INTEGER: 18541685
      SNMPv2-SMI::enterprises.1214.1.7 type=4  value=STRING: "test_zbxJCA-Critical"
      SNMPv2-SMI::enterprises.1214.1.8 type=2  value=INTEGER: 11
      SNMPv2-SMI::enterprises.1214.1.9 type=2  value=INTEGER: 3
      SNMPv2-SMI::enterprises.1214.1.10 type=4  value=STRING: "group"
      SNMPv2-SMI::enterprises.1214.1.11 type=4  value=STRING: "svc_acct_dev"
      SNMPv2-SMI::enterprises.1214.1.12 type=4  value=STRING: "servername"
      SNMPv2-SMI::enterprises.1214.1.13 type=4  value=STRING: "servername.domain.com"
      SNMP-COMMUNITY-MIB::snmpTrapAddress.0 type=64 value=IpAddress: 10.78.12.115
      SNMP-COMMUNITY-MIB::snmpTrapCommunity.0 type=4  value=STRING: "public"
      SNMPv2-MIB::snmpTrapEnterprise.0 type=6  value=OID: SNMPv2-SMI::enterprises.1214
    What we want to be able to do is depending on what the value in 1214.1.12 or 1214.1.13 have the action come from that server NOT from the origination of the trap which is another server entirely.
    Right now we have an item which is checking for the following -
    HTML Code:
    snmptrap[1214.1.4 type=2  value=INTEGER: 1$]
    and that calls a trigger which is setup like this -
    HTML Code:
    {Template_App_AppName_SNMP:snmptrap[1214.1.4 type=2  value=INTEGER: 1$].diff(0)}=1 and {Template_App_AppName_SNMP:snmptrap[1214.1.4 type=2  value=INTEGER: 1$].nodata(60)}=0
    The trigger name is currently -
    HTML Code:
    {HOST.NAME}: Tidal trap (Critical)
    Unfortunately HOST.NAME refers to the source of the message where-as we want it to be the value in 1214.1.12/13
  • Raziel
    • Apr 2017
    I know this is an old thread, but if you didn't figure it out already, you can solve your problem with Macro Functions.
