WebScenario POST json data
  • muelli
    • Jun 2021
    • 68
    Hello forum,
    I have a web scenario where I need to post JSON data.
    The manual curl is very easy for that:
    curl -X POST -H "Content-Type:application/json" -H "Authorization:Basic <API KEY>" -d "{'MSGSource':'Zabbix','Action':'ping'}" http://www.example.net/API
    However I seem to be too stupid to transform this into a web scenario. I added a the two headers:
    Content-Type => application/json
    Authorization => Basix <API KEY>
    And in the first and only step, I entered the json data as "Raw data" in post type like in curl:
    However I only get an HTTP 400 error code.
    Any advice or hints? Thanks!
  • muelli
    • Jun 2021
    • 68
    Suddenly it works, for whatever reason.
    Sorry can be closed
    • xtj
      • Apr 2024
      Hello Mueli .CanYou write little more about Your scenario ? What You exactly want to get and from where You send json body ? You create some script ? I have simillar problem when I send json body by post method from bash script using Scripts in Administration . I get response timeout. I try to find some fix in my case.
