Triggers go off during flexible schedule
  • gointern
    • Sep 2019
    What should I do to disable triggers during flexible schedule? I have set flexible schedule on ping during the night. What I found is that the trigger goes off that the item is not getting data.
    trigger:
    {Windows2008:agent.ping.nodata(5m)}=1
    • 4993
    "and ping.time()>210000 and ping.time()<070000"
    This works also without flexible schedule...
    • gointern
      • Sep 2019
      I would like to understand what does it do. Does this ignore after 21 hour and before 07 hour in the morning? I cannot seem to find anything in documentation.
      • gointern
        • Sep 2019
        I got "Incorrect trigger expression" which ever way I try to add. Using 5.0.3 zabbix. With expression constructor this passes validation.
        {Windows2008:agent.ping.nodata(10m)}=1 and {Windows2008:agent.ping.time()}>210000 and {Windows2008:agent.ping.time()}<070000
          • 4993
          Expression should be fine... I just added <>-s wrong way, this way it only works at nighttime.. ... they should be <210000 and >070000, then it works on daytime and not during 21-7...
          {Windows2008:agent.ping.nodata(10m)}=1 and {Windows2008:agent.ping.time()}<210000 and {Windows2008:agent.ping.time()}>070000
          No data has arrived in 10m and current time is less than 21 and more than 7.
          • gointern
            • Sep 2019
            Thank you. Tested and it works.
