Zabbix agent 2 configuration, include
  • veepee78
    • Jun 2020
    Does included files overwrite "main" configuration? If there is hostname in main config and in one include files, will include file's setting overwrite main config value? Would be too easy to add config modifications only to included files.. Tried to check documentation, but didn't clearly say.
    Yes they do overwrite general ones.
    some notes are here https://www.zabbix.com/documentation..._notes_include
    • veepee78
      • Jun 2020
      Thanks, yes I saw that one. Well maybe that information is included in this "Therefore do not define one parameter in several ''Include'' files (e.g. to override a general setting with a specific one)."
      Little clearer expression would be good..
