Template DB PostgreSQL doesn't use {$PG.PASSWORD}
  • stanski
    • Mar 2021
    Hi everyone,
    Using Zabbix server 5.0.9, running on Ubuntu 18.04, connecting to zabbix agent 5.0.20 on an Ubuntu 20.04 server with PostgreSQL 13.
    I've linked the "Template DB PostgreSQL" and set the {$PG.PASSWORD} macro for the host configuration. The postgres user zbx_monitor has been created.
    I've confirmed I can connect to the postgres db using the zbx_monitor user and password, however zabbix only shows errors.
    Example output of PostgreSQL: Get bgwriter:
    psql: error: connection to server at "127.0.0.1", port 5432 failed: FATAL: password authentication failed for user "zbx_monitor"
    Also, the template macros didn't include {$PG.PASSWORD} anywhere, so I have a feeling a password is not actually used.
    Thanks.
  • Answer selected by stanski at 09-02-2022, 16:47.
    cyber
    • 4949
    Password is used in many places in userparameters.
      • 4949
      • stanski
        • Mar 2021
        Originally posted by cyber
        https://git.zabbix.com/projects/ZBX/...Frelease%2F5.0
        Interesting. In the included template it doesn't appear to be the case.
        Example for PostgreSQL: Get bgwriter:
        pgsql.bgwriter["{$PG.HOST}","{$PG.PORT}","{$PG.USER}","{$PG.D B}"]
        I'll re-import the template XML from the repo.
        Thanks.
        Update: Overriding the included template with the one from the repo worked.
        • Steve Palmer
          • Apr 2022
          I've just fallen over this, but found another approach. On web page https://www.zabbix.com/documentation...x/zabbix_agent, table row "Template DB Postgress", column "Additional steps/comments", note 5 states:
          5. To monitor a remote server, create a .pgpass file in Zabbix agent home directory (/var/lib/zabbix/) and add rows with the instance, port, database, user and password information (see PostgreSQL documentation for details).
          Row examples:
          <REMOTE_HOST1>:5432: postgres:zbx_monitor:<PASSWORD>
          *:5432: postgres:zbx_monitor:<PASSWORD>
          This step is not mentioned on the https://git.zabbix.com/projects/ZBX/...Frelease%2F5.0 web page which instead mentions the {$PG.PASSWORD} macro, though this is not used in the supplied template.
