Email notification after docker restart
  • I.Ts
    • Feb 2022
    Hi guys,
    I have installed Zabbix 5.4 on Ubuntu 18. As clients I use the zabbixagent2.
    So that I can also monitor my docker containers I have imported the official template of Zabbix Docker Agent 2 https://git.zabbix.com/projects/ZBX/...Frelease%2F5.4
    Now everything works fine. But what doesn't work is that I get notified by email after my docker container restarts.
    Can anyone help me with this?
    P.S I am still inexperienced in Zabbix.
    Thanks in advance!
    So you want to get a notification about container restart? Is there a check for it? is there a trigger for it? is thee an action for it?
    from https://git.zabbix.com/projects/ZBX/...Frelease%2F5.4 I cannot see such trigger...
    I am not too familiar with all that docker stuff, but there seems to be an item "Container {#NAME}: Restart count" ... You could create trigger based on that (if increased then fire a trigger) and then work out the rest of it...
    • I.Ts
      • Feb 2022
      Hi. thank you for your answer and help.
      You are right, there is not a trigger.
      Can you give me an example of how the trigger should be set up?
        Without actually knowing, what that item returns .. Just guessing here
        Name: "Container {#NAME}: restarted"
        Expression: "abschange(/Docker by Zabbix agent 2/docker.container_info.restart_count["{#NAME}"])>0"
        maybe... But I have no experience with this template or containers...
