Good morning,
I configured Zabbix and snmptt for interpreting traps snmp, by testing generic Zabbix is able to recognize the trap but now I find myself configure snmptt to interpret traps from some of the video wall Conrac, they send traps as those set out below :
02/12/2015 14:06:35 172.30.12.12 (UDP: [172.30.12.12]: 1031 -> [172.30.0.155]: 162) TRAP, SNMP v1, community public
SNMPv2-SMI :: enterprises.30329.1.1 Enterprise Specific Trap (1) Uptime: 1 day, 2: 34: 26.10
SNMPv2-SMI :: = INTEGER enterprises.30329.1.1.2.1.2.8.0: 0
04/12/2015 09:41:00 172.30.12.90 (UDP: [172.30.12.90]: 1044 -> [172.30.0.155]: 162) TRAP, SNMP v1, community public
SNMPv2-SMI :: enterprises.30329.1.1 Enterprise Specific Trap (1) Uptime: 15 days, 9: 23: 11.65
SNMPv2-SMI :: = INTEGER enterprises.30329.1.1.2.1.1.2.0: 91
I snmptt.conf.conrac configured as follows:
MIB: CONRAC (file: /usr/share/snmp/mibs/IPCIX45GM_2.mib) converted on Sun Nov. 15 2015 21:04:56 using snmpttconvertmib v1.3
EVENT Display_CPU_TEMP CONRAC :: ipc.0.1 "DU event" Warning
FORMAY ZVXTRAP $ ar CPU Temp: "$ 1"
SDESC
Temperature High CPU
EDESC
EVENT Display_CPUFAN CONRAC :: speed-1.0 "DU event" Warning
FORMAY ZVXTRAP $ ar CPU FAN speed: "$ 1"
SDESC
CPU fan Locked
EDESC
With this configuration snmptt not recognize the trap and then file snmpttunknown.log
02/12/2015 14:06:35: Unknown traps (.1.3.6.1.4.1.30329.1.1.0.1) received from at 172.30.12.12:
Value 0: 172.30.12.12
Value 1: 172.30.12.12
Value 2: 1: 2: 34: 26.10
Value 3: .1.3.6.1.4.1.30329.1.1.0.1
Value 4: 172.30.12.12
Value 5: public
Value 6: .1.3.6.1.4.1.30329.1.1
Value 7:
Value 8:
Value 9:
Value 10:
Ent Value 0: 0 = .1.3.6.1.4.1.30329.1.1.2.1.2.8.0
04/12/2015 09:40:54: Unknown traps (.1.3.6.1.4.1.30329.1.1.0.1) received from at 172.30.12.90:
Value 0: 172.30.12.90
Value 1: 172.30.12.90
Value 2: 15: 9: 23: 05.67
Value 4: 172.30.12.90
Value 5: public
Value 7:
Value 8:
Value 9:
Value 10:
Ent Value 0: .1.3.6.1.4.1.30329.1.1.2.1.1.2.0 = 91
I did not understand how to set parameters snmptt.con.conrac
Someone able to help me?
Greetings
SDESC
EDESC
SDESC
CPU fan Locked
EDESC
Value 5: public
Value 7:
Value 8:
Value 9:
Value 10:
Value 5: public
Value 7:
Value 8:
Value 9:
Value 10:
Greetings
