Zabbix site is not opening(Just after installation)
  • yatta
    • Feb 2022
    • 82
    I just installed Zabbix on Suse SLE15.
    I followed every steps and also installed front-end from here --> https://www.zabbix.com/documentation...lling_frontend
    I copied all PHP servers to /srv/htdocs/zabbix directory.
    Installed packages;
    server:/srv/www/htdocs/zabbix # rpm -qa |grep zabbix
    zabbix-web-mysql-5.4.10-1.sles15.noarch
    zabbix-server-mysql-5.4.10-1.sles15.x86_64
    zabbix-proxy-mysql-5.4.10-1.sles15.x86_64
    zabbix-agent-5.4.10-1.sles15.x86_64
    zabbix-web-deps-5.4.10-1.sles15.noarch
    zabbix-apache-conf-5.4.10-1.sles15.noarch
    zabbix-web-5.4.10-1.sles15.noarch
    zabbix-sql-scripts-5.4.10-1.sles15.noarch
    After this point, regarding to instructions, I able to reach GUI with "http://server_IP/zabbix"
    But it's not. First it's redirecting https site, I don't know why, then fails with no error.
    I can't find "httpd" service, is that normal?
    server:/srv/www/htdocs/zabbix # service --status-all | grep zabbix
    zabbix-server.service loaded active running Zabbix Server
    server:/srv/www/htdocs/zabbix # service --status-all | grep httpd
    What am I missing?
    Kind regards.
    • 4993
    Did you install webserver? Was there a good reason to compile it by yourself and not install from packages? Package install usually resolves your dependencies also... like installs a webserver or DB...
    • yatta
      • Feb 2022
      • 82
      Hi! Which package is exactly web server? I installed packages below;
      server:/run/zabbix # rpm -qa | grep zabbix
        • 4993
        Do you have an apache or nginx installed there?
        • yatta
          • Feb 2022
          • 82
          I used Apache;
            • 4993
            This is not apache webserver... its just zabbix related config...
            As you say, something opens, then maybe you have there nginx?
