send email when problem is solved
  • ab-tech
    • Sep 2020
    • 20
    i have a zabbix server with few trigger.
    when trigger have a problem zabbix sends me an email, and works fine.
    but i would receive an email when problem is solved.
    similar to
    subject email: Problem [open] - hostname - ....
    then
    subject email: Problem [close] - hostname - ....
    i setup SMTP of course and action
    with
    steps 1-1
    step duration 0
    but i don't undestand this configuration...
    thank you in advance
  • Atsushi
    • Aug 2013
    • 2028
    Did you add Recovery operations in the action settings?
    • ab-tech
      • Sep 2020
      • 20
      thank you!!!
      was so simple....
      sorry for ask...
