Zabbix Windows agent problem (1053)
  • Jordioa18
    • Dec 2015
    For a project in internship I have to make a Zabbix machine so it would replace Nagios, but I am running into a problem with installing the Windows agent, the service won't start.
    I did modify the conf to the Zabbix server IP and and my own laptop (Of course) and installed the config, but when I want to start the service, I get error 1053. I tried searching on internet, but I can't find anything. Do you guys know a solution?
  • maaboo
    • Sep 2014
    • 17
    If service doesn't start there is 99% an error in the conf file (parse error).
    Comment every changed line one by one to find it.
    • sticks221
      • Mar 2016
      • 9
      Double check that you're running the correct version for your OS - the 32bit version will install on a 64bit OS and vice-versa but will fail to start.
