Zabbix Proxy 6.0 LTS missing file schema.sql.gz
  • Robert N.
    • Feb 2022
    • 28
    Hi, I was trying to install Zabbix proxy 6.0 LTS and if I run "sudo zcat /usr/share/doc/zabbix-sql-scripts/mysql/schema.sql.gz | mysql -uzabbix -p zabbix_proxy" - the file is missing. There is a new file "proxy.sql" and if I put it into the proxy.sql.gz then I succesfully run the script and the proxy.
    How will be the new command for proxy.sql without .gz? THX
  • Robert N.
    • Feb 2022
    • 28
    Got it :
    sudo cat /usr/share/doc/zabbix-sql-scripts/mysql/proxy.sql | mysql -uzabbix -p zabbix_proxy
    • ripperSK
      • Jul 2019
      • 42
      For zabbix 6.0 (and probably newer) I learned the hard way - you need to install package
      zabbix-sql-scripts
      in order to have
      directory populated with .sql DB initialisation scripts.
      • bewog
        • Apr 2023
        Nothing in the package for Debian 11 Bullseye either:
        # dpkg-query -L zabbix-proxy-sqlite3
        /etc
        /etc/init.d
        /etc/init.d/zabbix-proxy
        /etc/logrotate.d
        /etc/logrotate.d/zabbix-proxy-sqlite3
        /etc/zabbix
        /etc/zabbix/zabbix_proxy.conf
        /lib
        /lib/systemd
        /lib/systemd/system
        /lib/systemd/system/zabbix-proxy.service
        /usr
        /usr/lib
        /usr/lib/tmpfiles.d
        /usr/lib/tmpfiles.d/zabbix-proxy.conf
        /usr/lib/zabbix
        /usr/lib/zabbix/externalscripts
        /usr/sbin
        /usr/sbin/zabbix_proxy
        /usr/share
        /usr/share/doc
        /usr/share/doc/zabbix-proxy-sqlite3
        /usr/share/doc/zabbix-proxy-sqlite3/changelog.Debian.gz
        /usr/share/doc/zabbix-proxy-sqlite3/changelog.gz
        /usr/share/doc/zabbix-proxy-sqlite3/copyright
        /usr/share/man
        /usr/share/man/man8
        /usr/share/man/man8/zabbix_proxy.8.gz
        /var
        /var/log
        /var/log/zabbix
        Do you known where i can find it ?
        I'm looking for sqlite3 schema.
        Thank you
        • Glencoe
          Zabbix developer
          • Oct 2019
          • 153
          Bewog, the previous comments relate to MySQL schema. You don't need schema files for SQLite, the SQLite version of zabbix_proxy creates the schema automatically.
