Step-by-Step Guide: Upgrade Zabbix (4.x, 5.x) to 6.0 or install it from scratch
  • ZaBeast
    • Sep 2019
    • 42
    Upgrade Zabbix to 6.0:
    Zabbix 6.0 is out and I have written a step-by-step guide on how to upgrade Zabbix monitoring system (4.x, 5.x) to 6.0 version on Ubuntu/CentOS/RHEL/Debian/Rasbian:
    https://bestmonitoringtools.com/how-...atest-version/
    Fresh Zabbix 6.0 Installation and optimization guides:
    If you need a guide on how to do fresh Zabbix installation and optimize the Zabbix server/database, please check these links:
    Ubuntu: https://bestmonitoringtools.com/how-...ver-on-ubuntu/
    CentOS/RHEL: https://bestmonitoringtools.com/how-...entos-or-rhel/
    Debian: https://bestmonitoringtools.com/how-...ver-on-debian/
    Raspberry Pi: https://bestmonitoringtools.com/how-...y-pi-raspbian/
    • 4996
    Having latest platform and doing this is piece of cake. But how many of you run your old 4 or 5 LTS versions on a latest OS versions, supported by 6LTS? I suspect not too many. Upgrading platform AND product at the same time will be much more complicated....
    • wittie
      • Dec 2020
      HI ZaBeast,
      Thank you for sharing your steps or guide. Hope you can also provide us upgrading zabbix using centos7
        • 4996
        Originally posted by wittie
        HI ZaBeast,
        Start with upgrading to Centos8 ..:P
        • firo1603
          • Sep 2021
          hellow ,i got a problem on raspberrypi 4B
          i install zbx 6.0.2 ,the os version is bullseye
          but when i complete installation,the zabbix server crashing for every three minutes
          i try to make a new installation(include the os,database,nginx and any more),but the problem has not be solve
          i creat a issus on zabbix support,you can find the log for this problem
          can you help me ?
          • firo1603
            firo1603 commented
            i make ne fresh install on 64bit os,it working without the same problem
        • Mighty33
          • Jun 2022
          I was getting an error when following the install.
          $ sudo apt update
          Hit:1 http://us.archive.ubuntu.com/ubuntu focal InRelease
          Hit:2 http://us.archive.ubuntu.com/ubuntu focal-updates InRelease
          Hit:3 https://linux.teamviewer.com/deb stable InRelease
          Hit:4 http://us.archive.ubuntu.com/ubuntu focal-backports InRelease
          Hit:5 http://security.ubuntu.com/ubuntu focal-security InRelease
          Get:7 https://dlm.mariadb.com/repo/mariadb....6/repo/ubuntu focal InRelease [4,717 B]
          Hit:8 https://repo.zabbix.com/zabbix/6.0/ubuntu focal InRelease
          Hit:6 https://downloads.mariadb.com/Tools/ubuntu focal InRelease
          Get:9 https://dlm.mariadb.com/repo/maxscale/latest/apt focal InRelease [6,384 B]
          Fetched 11.1 kB in 1s (9,996 B/s)
          Reading package lists... Done
          Building dependency tree
          Reading state information... Done
          2 packages can be upgraded. Run 'apt list --upgradable' to see them.
          N: Skipping acquire of configured file 'main/binary-i386/Packages' as repository 'https://repo.zabbix.com/zabbix/6.0/ubuntu focal InRelease' doesn't support architecture 'i386'
          Can anyone help me on this?
        • hai.dao
          • Jun 2022
          • 19
          Hi, it means we can not upgrade 5.x to 6.0 when using centos 7 ???
            • 4996
            yes. you cannot run 6.0 on Centos7.
            • hai.dao
              • Jun 2022
              • 19
              Hi bro.
              i'm using Zabbix 5.0.1 - centos 7
              - STEP 4 : upgrade database , i can't see upgrade success or fail like your manual post.​
              • Atsushi
                Atsushi commented
                Unless you change to an OS such as CentOS 8, you cannot build a Zabbix 6.0 server environment using official packages. If you are still on CentOS 7 and intend to update using official packages, your Zabbix server version is old and not updated. Therefore, database upgrade processing will not be performed.
