Issue with LLD json processing
  • Damien_Dye
    • Apr 2021
    • 10
    I have an issue with LLD version 6.
    I have a template am building
    I have a key
    SSH directory content
    vfs.dir.get[/etc/ssh,^ssh.*,^ssh_config,file,,0,,,,,]
    returns json
    [{"basename":"sshd_config","pathname":"/etc/ssh/sshd_config","dirname":"/etc/ssh","type":"file","user":"root","group":"root","p ermissions":"0600","uid":0,"gid":0,"size":4269,"ti me":{"access":"2022-02-08T11:31:16+0000","modify":"2021-05-27T16:54:22+0100","change":"2022-02-02T12:13:30+0000"},"timestamp":{"access":164431987 6,"modify":1622130862,"change":1643804010}},{"base name":"ssh_host_ed25519_key","pathname":"/etc/ssh/ssh_host_ed25519_key","dirname":"/etc/ssh","type":"file","user":"root","group":"985","pe rmissions":"0600","uid":0,"gid":985,"size":387,"ti me":{"access":"2022-02-15T12:24:11+0000","modify":"2020-08-03T09:51:15+0100","change":"2022-02-02T12:32:09+0000"},"timestamp":{"access":164492785 1,"modify":1596444675,"change":1643805129}}]
    I have a discovery key with the following LLD macro
    $..basename
    I have an item prototype
    key : ssh.owner.[{#BASENAME}]
    preprocessing
    json path $[?(@.basename == "{#BASENAME}")].uid
    replace [
    replace ]
    issue is the keys are getting created like
    ssh.owner.["["sshd_config"]"]
    instead of like
    ssh.owner.["sshd_config"]
    which then cause my preprocessing to fail.
    how can I go about fixing the discovery rule to correctly name the keys ?
  • Noobz
    • Jun 2020
    • 105
    I asked this question just recently, and filed a bug report.
    It is actually the expected behaviour as per the documentation, it just doesn't make sense as to why anyone would want it to do that.
    When a path is indeterminate ( which apparently a discovery is), an array (square brackets) of one object is returned, rather than just the value. This means that it is impossible to use LLD macros with JSON path effectively.
    I would be elated to be proven wrong!
      • 5002
      Just during the last week, there was very similar post ...
      If your preprocessing returns an array ([]-s), then you can refer to the first (and only) element by adding ".first"
      $[?(@.basename == "{#BASENAME}")].uid.first() (I think)
      • Noobz
        • Jun 2020
        • 105
        Again - this doesn't work if the array is generated by the macro resolution - the macro itself resolves to ["something"] instead of "something", there is no process available to amend a macro value once it has been generated.
        So, the array is returned as a function of the LLD macro, not JSON preprocessing.
        • Damien_Dye
          • Apr 2021
          • 10
          ok based on the theme of using .first()
          I appended the LLD macro
          from $..basename
          to $..basename.first()
          which now produces the expected result. really counter intuitive.
          • Noobz
            • Jun 2020
            • 105
            from $..basename
            That makes zero sense! I'll have to give that a go... And apologise to cyber assuming it works in the scenario I am working with.
            • Noobz
              • Jun 2020
              • 105
              Use quotes when you're quoting someone.
              • Noobz
                • Jun 2020
                • 105
                Thank you - this works but as above, is certainly not an intuitive answer.
                • pardhak25
                  • Mar 2021
                  Try like this LLD macro {#BASENAME} = $.basename (single dot) this should give only the value without "[]".
                  • kyus
                    • Feb 2024
                    • 210
                    This worked in my case, thanks. I ended up not even using preprocessing, because when I tried to, it wouldn't store the JSON values in the LLD macro.
