zabbix 6.0 Proxy no sql file
  • yusewy
    • Feb 2022
    I have setup zabbix 6.0 proxy, but there is no path /usr/share/doc/zabbix-sql-scripts in my system, can someone help me?
    My OS is Centos 8.2, and I did below commands
    rpm -Uvh https://repo.zabbix.com/zabbix/6.0/r...el8.noarch.rpm
    dnf clean all
    dnf install zabbix-proxy-mysql
  • Answer selected by yusewy at 17-02-2022, 10:14.
    Atsushi
    • Aug 2013
    • 2028
    Try install the package zabbix-sql-scripts and check the directory /usr/share/doc/zabbix-sql-scripts/mysql.
    • yusewy
      yusewy commented
      Thank you, Atsushi! it worked.
  • Atsushi
    • Aug 2013
    • 2028
    • yusewy
      yusewy commented
