Full Zabbix experience with SNMP?
  • Jaiibee
    • Dec 2015
    I'm sorry - I really, really am - if this is a repeatedly asked query.
    Basically, our infrastructure all runs with SNMP. From servers to switches. Don't ask.
    Basically, after playing around with Zabbix for a few weeks, I've decided to try get monitoring in a similar manner that Nagios is doing it. I have a few servers, have tried applying templates and the most I have is uptime which is quite broing to graph.
    I have Googled far and wide, have got a lot of information, and I'm still struggling to break ground breaking progress. I understand that I must configure SNMP stuff, and an SNMP trap, but I can't find a tutorial dedicated to explaining all of this to me and the documentation isn't spectacularly helpful for this particular instance.
    My big question - my elaborate, brain tingling inquiry; what is the best method of monitoring a server - using SNMP - and having all the graphs available just like if it were being monitored by the zabbix agent?
  • Colttt
    • Mar 2009
    • 878
    what OS do you want to monitor? windows? linux? In zabbix they are already template to monitor windows/linux via snmp! did you try this templates?
    Debian-User
    Sorry for my bad english
    • Jaiibee
      • Dec 2015
      Thanks for the snappy reply
      I'm having an issue monitoring Windows servers with SNMP. I can get uptime and (I think) CPU, but I'm having issues with other factors.
      There's also no graphs - which I'm sure wouldn't be too hard once configured - but as long as I can get metrics measured I'm happy
      • Colttt
        • Mar 2009
        • 878
        hmm did you get any errors?
        What issues do you have?
        A good start to debug this is to install snmp on you zabbix-server and try something like
        snmpget -v<VERSION> -c <COMMUNITYSTRING> <IP> <OID>
        snmpget -v2c -c public 10.20.30.40 vm.memory.size[free]
        does it work? if not please run and install
        apt-get install snmp-mibs-downloader
        download-mibs
        take also a look at https://wiki.debian.org/SNMP, if something dont work please post the errormessage!
        Debian-User
