How can I use parameters in HTTP agent based items for REST API based monitoring
  • apulai
    • Feb 2022
    I would like to monitor a system via REST API.
    I am putting together a template, with HTTP agent based items on it.
    The basic data collection is OK.
    Now I would like collect only the last notification from the source system, so I would need
    to add a filter to the HTTP / REST request.
    I could not really figure out how to use a user macro in the query fields.
    I thought this should work, and {$LAST_NOTIFICATION_ID} will be substituted, but it is not:
    The macro is super simple:
    {$LAST_NOTIFICATION_ID} = 832
    Any advise here?
    I would like to go also one step further:
    Between my items in this template there is a key called 'id', which gets updated OK.
    In fact I would like to substitute the value of this id, into my http request. "id gt 'value of(nbunotification:id)'"
    Could not figure out how to do it.
    Your kind help would be really appreciated.
    Andras
    You cannot use other items value in key values...
    • apulai
      • Feb 2022
      Hi Cyber,
      Yes that sounds totally logical: keys should be static.
      But this is not what I want to do:
      - I would like to use the value of a key in my query.
      Here is what I trying to accomplish:
      - after the first REST call key id holds the value 832.
      I look at it like vairable called id = 832
      - in my next REST call I would like to get only events where id is greater than 832.
      So in the HTTP params i expect something like: ?query="id gt 832"
      This is what I am trying to explain in the UI like this:
      http query:
      filter. := "id gt (value stored in variable or key called 'id') "
      Thanks,
      Hope I could explain it better.
      Pls try to help.
