How to formulate a trigger if HTTP agent succeeds or not?
  • yurtesen
    • Aug 2008
    • 130
    I have a raw item which fetches data using HTTP agent. This data is NOT stored in database, but used by discovery rules and in turn dependent items which are discovered.
    Since the data fetch does not store any data, how can one check if the data fetch worked eg. for last 1h? Any suggestions?
    It would be hard to make triggers on the discovery rules as it is not possible to know beforehand if anything will be discovered or not.
    Add another dependent item, which has JS preprocessing, make that JS to ignore anything from master and just return timestamp for "now". Each time your master item fetches new data, this item will be updated. Make trigger based on that.
    • yurtesen
      • Aug 2008
      • 130
      Thank you cyber
      That was what I expected the solution to be but hoped there would be a better way.
