Problem with Item in autodiscovery
  • seraph
    • Feb 2022
    I'm using zabbix in version 5.4.4 and i have an issue with autodiscovery.
    Generated JSON file are OK and i have in it below example data:
    {"data": [{"channelID": 1, "channelSystemID": "monitor"}, {"channelID": 3, "channelSystemID": "monitor2"}, {"channelID": 24, "channelSystemID": "monitor3"}]}
    and issue appear when i try to add item.
    in script for item i'm trying to get value according to channelID what works when i run that script.
    When i set in item key channelStatus[{#channelID}]
    i receive information:
    Cannot create item: item with the same key "channelStatus[{#channelID}]" already exists.
    Please help me what am i doing wrong.
    Best Regards.
  • LenR
    • Sep 2009
    • 1011
    All examples seem to have the keys in uppercase, like {#CHANNELID}, I don't know if that is a requirement or if you could fix this in preprocessing
    • seraph
      • Feb 2022
      i've changed all information to uppercase, in json file and in zabbix configuration
      and i still receive this information
      Cannot create item: item with the same key "channelStatus[{#CHANNELID}]" already exists.
      • seraph
        • Feb 2022
        i've got some new info from debuging zabbix
        30441:20220221:131121.826 In substitute_lld_macros() data:'Channel state for [{#CHANNELSYSTEMID}]'
        30441:20220221:131121.826 cannot substitute macro "{#CHANNELSYSTEMID}": not found in value set
        30441:20220221:131121.826 End of substitute_lld_macros():SUCCEED data:'Channel state for [{#CHANNELSYSTEMID}]'
        30441:20220221:131121.826 In substitute_key_macros_impl() data:'channelStatusAPI[{#CHANNELID}]'
        30441:20220221:131121.826 In substitute_lld_macros() data:'{#CHANNELID}'
        30441:20220221:131121.826 cannot substitute macro "{#CHANNELID}": not found in value set
        30441:20220221:131121.826 End of substitute_lld_macros():SUCCEED data:'{#CHANNELID}'
        30441:20220221:131121.826 End of substitute_key_macros_impl():SUCCEED data:'channelStatusAPI[{#CHANNELID}]'
        30441:20220221:131121.840 query [txnlev:0] [select key_ from items where hostid=10084 and key_='channelStatusAPI[{#CHANNELID}]']
        in json file i've got only one record:
        {"data": [{"CHANNELID": 1, "CHANNELNAME": "switch_monitoring_c", "CHANNELSYSTEMID": "monitor", "CHANNELSTATUS": "offline"}]}
        configuration Item prototypes in zabbix:
        Name: Channel state for [{#CHANNELSYSTEMID}]
        Key: channelStatusAPI[{#CHANNELID}]
        and i still receive information:
        Cannot create item: item with the same key "channelStatusAPI[{#CHANNELID}]" already exists.
          I don't see you setting LLD macros anywhere... Have you pointed those {#CHANNELID} and {#CHANNELSYSTEMID} to correct json path?
          • seraph
            • Feb 2022
            Thank You cyber for this tip
            i've add LLD macro and all works now.
            • lptarik
              lptarik commented
              How did you solve your issue?
          • seraph
            • Feb 2022
            I just add LLD macro in autodiscovery configuration
            i've put names that i have in json file according to variables used in item Key
