auto discovery SNMP OIDs
  • robertkwild
    • Feb 2022
    • 9
    hi all,
    i want to be able to get zabbix server to auto discover hosts, ive already enabled SNMPv2 on all my linux/switches
    i want to put a wild card in the OID but i dont know what one to use, going by this link
    https://www.zabbix.com/documentation...very/snmp_oids
    i would had thought 1. would had done it as 1. would had captured everything
    thanks,
    rob
  • mickey4691
    • Feb 2022
    Do you think this video might help?
    Video Link -> https://www.youtube.com/watch?v=YUzWZTDOCFM
    • robertkwild
      • Feb 2022
      • 9
      mmm.. probably doing somethign wrong here
      i attach pics
      i then go to monitoring > discovery and it hasnt discovered anything
      • mickey4691
        • Feb 2022
        What if you were to just set the range to pull one or two valid devices that you know?
        • robertkwild
          • Feb 2022
          • 9
          is there a way to import all the OIDs that i get from the snmpwalk command?
          • mickey4691
            • Feb 2022
            I am not sure. I'm looking for help myself in regards to discovery -> https://www.zabbix.com/forum/zabbix-...-rules-to-work
            That's when I found that YouTube video which looks similar to what you are working with.
            • robertkwild
              • Feb 2022
              • 9
              i think were barking up the wrong path here as i think its templates we need to mess about with, like the one i attach
              just instead of cpu discovery and the oid, need to make them wildcards
              • robertkwild
                • Feb 2022
                • 9
                Can anyone help me ot on this please as I'm srruggling
                I just want it to autodiscover all my hosts on a network and add all the snmp oids it finds on each host it finds
                Thanks,
                Rob
                • dany2191
                  • Aug 2023
                  en el campo SNMP OID puedes colocar lo siguientes 1.3.6.1.2.1.1.1.0
