MS-SQL Database Query Monitors
  • deepaks
    • Nov 2015
    • 12
    Hi Friends,
    I want to monitor MS-SQL Database by running remote database queries on the host from zabbix. I found something like "Database monitor" type in items section, but want someone to help me this.
    How to configure items?
    How to configure items on those items?
    Thanks in advance.
  • Colttt
    • Mar 2009
    • 878
    hello,
    at first you need to install unixodbc on you distribution, and also a ms-sql-odbc-driver
    if that conection works (you can try it with the command 'isql' ) than you can query this database in zabbix with the item database monitor.
    further information:
    and an how-to:
    http://lab4.org/wiki/Zabbix_Database_Monitor_English
    Debian-User
    Sorry for my bad english
    • deepaks
      • Nov 2015
      • 12
      Hi Colttt,
      I had installed the required drivers, but when I am trying to run isql command from server its showing me
      isql -v DSN USERNAME PASSWORD
      [S1000][unixODBC][Oracle][ODBC][ORA]ORA-12541: TNS:no listener
      [ISQL]ERROR: Could not SQLConnect
      Kindly what I should do to solve this issue.
      Thanks in advance.
