search item with variable in name
  • ab-tech
    • Sep 2020
    • 20
    i'm using zabbix 5 LTS to monitor some printers with Universal Printer Template.
    works all fine, but when i go
    zabbix - monitoring - host - <some printer> - latest data
    and search in
    name = toner
    item with name toner exists but i think is a variable writed from template...
    so how can i search item with variable in name?
    thank you in advance
  • BayramGrbz45
    • Sep 2020
    • 16
    Hello.
    I can no longer find your printer template that I used before. Is it possible for you to share this teplate with me?
    Thank you.
    https://web.archive.org/web/20200920...inter-template
    • ab-tech
      • Sep 2020
      • 20
      here you are.
      but why zabbix remove this template???
      in zabbix 6 how i monitor my printers???
      thank you
        Zabbix share is no more... https://github.com/zabbix/community-templates is the place to use for community templates.
        • BayramGrbz45
          • Sep 2020
          • 16
          Thank you so much
