use OIDs from snmpwalk for template
  • robertkwild
    • Feb 2022
    • 9
    hi all,
    is there a way to use the OIDs from the snmpwalk command i run on my zabbix server for my opnsense firewall, instead of using a specific template when i create the host
    as im using the PFSENSE template for my opnsense firewall and it doesnt like it, as it complains i have a problem about the web interface is down but its not
    thanks,
    rob
  • tikkami
    • May 2018
    • 71
    OPNsense just don't have all the same OIDs (BEGEMOT-MIB) available what are found from pfSense.
    $ snmpwalk -v2c -c public 192.168.0.1 1.3.6.1.4.1.12325
    SNMPv2-SMI::enterprises.12325 = No Such Object available on this agent at this OID
    My OPNsense version:
    OPNsense 21.7.8-amd64
    FreeBSD 12.1-RELEASE-p22-HBSD
    • robertkwild
      • Feb 2022
      • 9
      Yeah I knew the oids weren't the same I knew one was out or a few
      Is there a way to input my oids from the snmp walk I ran into this host
      • tikkami
        • May 2018
        • 71
        You just want to collect all (or some) oids which can be seen by snmpwalk?
        It could be done by external script which runs snmpwalk. Then some js preprocessing and LLD rules...
        Or add items semi-automatically by api script.
        • robertkwild
          • Feb 2022
          • 9
          I want to import the oids that snmpwalk has picked up, can I do that
          I tried doing the auto discovery snmp but I didn't know how to get it to pick up my oids from a host I added
          • tikkami
            • May 2018
            • 71
            Yes, than can be done like I wrote previously.
            However, I don't understand why you want to do that. There are quite much unrelevant information.
            I would just add manually those oids which are really important.
            AFAIK interesting firewall statistics aren't available from Opnsense by SNMP.
            • robertkwild
              • Feb 2022
              • 9
              When you say js pre processing what is this please
              I know LLD rules are auto discovery rules?
