Offline disk trigger
  • jvdb
    • Feb 2022
    • 23
    Is there a way to check if a disk is offline?
    Sometimes when we reboot a server a disk doesn't get online and we would like to let Zabbix check this for us.
    We run Zabbix 4.4.10, we are setting up a Zabbix 6 server..
  • jvdb
    • Feb 2022
    • 23
    There is no option?
      If you did not find any existing item, that does this for you, then ask your friendly linux(??) admin, how s/he would check for that kind of situation from command line and build your check around that.
      • jvdb
        • Feb 2022
        • 23
        well yeah its a windows server so that wont do it
          That's why I added (??) there after linux.. Same question can be asked from windows admin..
