Cisco Nexus 9k Average CPU/Memory Utilization
  • brucebay
    • May 2020
    • 13
    How to pull Cisco Nexus 9k Average CPU/Memory Utilization through SNMP, since the device has multiple cores? I need to know what SNMP OID polls average CPU process for a multicore device like Nexus 9k,
    what I am trying to get is the last line of "show process cpu" as follows:
    CPU util : 1.08% user, 1.41% kernel, 97.50% idle
    or "show system resources"
    Load average: 1 minute: 0.20 5 minutes: 0.47 15 minutes: 0.51
    Processes : 597 total, 3 running
    CPU states : 1.50% user, 1.41% kernel, 97.08% idle
    Memory usage: 32828716K total, 5714464K used, 27114252K free
  • Noobz
    • Jun 2020
    • 105
    If you read the documentation from Cisco - it tells you exactly which OID's to monitor
    • brucebay
      • May 2020
      • 13
      Noobz, you don't need to respond when you do not know the answer.
      learn keeping your unsolicited advices to yourself.
      • tim.mooney
        tim.mooney commented
        Wow. I thought Noobz's response was perfectly valid. Your follow-up, on the other hand...
        cyber commented
        Some people ....
        Care to do some work by yourself or you wish everything to be handled to you on a silver plate?
    • Noobz
      • Jun 2020
      • 105
      I guess the OP just needs someone to google things for them:
      https://www.cisco.com/c/en/us/suppor...util-snmp.html
