cannot stat SNMP trapper
  • chukynax
    • Dec 2015
    Please help needed.
    I have configured zabbix, im trying to start work with catching all snmp traps from cisco devices.
    i have installed snmptt snmptrapd
    everything works perfect, i get file /tmp/zabbix_traps.tmp
    but zabbix write the following in log:
    12034:20151215:190943.567 cannot stat SNMP trapper file "/tmp/zabbix_traps.tmp": [2] No such file or d
    irectory
    File exists and contains following traps:
    19:07:45 2015/12/15 enterprises.9.9.43.2.0.1 Normal "General event" 172.16.20.6 - ZBXTRAP 172.16.20.6 g
    eneral enterprises.9.9.43.1.1.6.1.3.66:1 enterprises.9.9.43.1.1.6.1.4.66:3 enterprises.9.9.43.1.1.6.1.5
    .66:4
    other topic is
    i get this mib enterprises.9.9.43.1.1.6.1.4.66:3, it when i do wr on the cisco device, before snmptt worked it was just numbers, so it means snmptt works, but why i cant see CONFIG SAVED for example.
