Steps to update zabbix using centos 7
  • wittie
    • Dec 2020
    Hi Team,
    Do we have steps that we can use to update our zabbix?
    Operating System: CentOS Linux 7 (Core)
    zabbix_server (Zabbix) 5.0.20
    Revision bf8d9f8abb 31 January 2022, compilation time: Jan 31 2022 12:45:56
    Copyright (C) 2022 Zabbix SIA
    License GPLv2+: GNU GPL version 2 or later <http://gnu.org/licenses/gpl.html>.
    This is free software: you are free to change and redistribute it according to
    the license. There is NO WARRANTY, to the extent permitted by law.
    This product includes software developed by the OpenSSL Project
    for use in the OpenSSL Toolkit (http://www.openssl.org/).
    Compiled with OpenSSL 1.0.1e-fips 11 Feb 2013
    Running with OpenSSL 1.0.1e-fips 11 Feb 2013
    5.0.20 seems to be latest in v5.0 series...
    For starters you need CentoOS8 for upgrading to v6.
    • GeanWatte
      • Mar 2023
      To get started, you may want to check out the official Zabbix documentation for instructions on how to update your version. It's always important to ensure that your operating system is compatible with the new version of zabbix.
      • GeanWatte
        • Mar 2023
        Speaking of operating systems, I must mention that CentOS 7 is reaching its end of life. To ensure the security and stability of your system, you may want to consider getting extended lifecycle support from tuxcare.com, as they provide solutions for CentOS 7.
