net-snmp and zabbix
  • James Tinkess
    • Jun 2021
    net-snmp and zabbix
    I am running redhat 8.1 on Azure ,and zabbix 4.0.32 which uses net-snmp-5.8-12
    I want to upgrade to Zabbix 6, i went through the upgrade steps without incident. When i startup Zabbix6, i am getting the undefined symbol error AES192..etc etc
    The fix for this is to upgrade net-snmp to at least 5.8-18.
    The dnf upgrade net-snmp command keeps reporting no upgrades- which is b.s obviously.
    How do i get my repos to see the upgraded version? or how do i get an upgraded version without recompiling a source distribution.
    I can seem to install any of these rpm's? https://rpmfind.net/linux/rpm2html/s...query=net-snmp
    Im sure i am missing something very basic and would appreciate any tips.
    thanks
  • Atsushi
    • Aug 2013
    • 2028
    With RHEL 8.1, you will not be able to build a new version of Zabbix server using the packages on the official Zabbix repository. I think you should upgrade your RHEL version to 8.3 or later. And if you're using RHEL, you should use the repository provided by Red Hat. Check the contents of /etc/yum/vars/releasever in your environment. If the string 8.1 is set, you can upgrade it from 8.1 to a newer version by specifying a version of 8.3 or later. I recommend updating to the latest version(8.5?), if possible.
