How to know when an event/problem has been resolved via API?
  • Luanpablo100
    • Mar 2022
    I'm making a Power BI panel receiving data from Zabbix via API, but I would like to know when a problem was solved to know how long it was on alert. Does anyone know how to do it? I've looked at several pages but I only find the moment of creation, not resolution.
    I'm using Zabbix 6.0.0
    • 4993
    Problem object has clock and r_clock properties... r like resolution...
    • amedina
      • Apr 2023
      how can I filter the results from problem.get to get only problems with values in r_clock?
      Thanks and best regards.
