ICMP Trigger Issue
  • zabbixnoob123098452145
    • Mar 2022
    ICMP Trigger Issue
    Hello Everyone,
    Super new to Zabbix and Linux environment and currently facing issues with icmp ping trigger.
    Running Zabbix version 3.4.7
    this is affecting all host(Server and network) present in zabbix.
    we havent changed anything in terms of templates which will cause this.issue
    Error - Cannot evaluate expression: "Cannot evaluate function "ServerName:icmppingloss.max(600)": item is not supported"
    Steps take
    all i have done is login to Zabbix server and tried to ping one server in each subnet and i am getting response. so that show zabbix is able to reach all our subnets.
    Could anyone assist or seen this kind of issue.
    Your trigger calculation fails as the item you are using is on "not supported" state. Try to look up, why is that item in such state. There is probably a red ! icon and you should see some kind of error message, if hovering over it.
      • Mar 2022
      didnt realise item has their own error as well.
      below is the error from item
      fping failed: (null): can't create raw socket (must run as root?) : Address family not supported by protocol
        Documentation is your friend..
        Are all the permissions in place for fping?
          • Mar 2022
          how can i check the permissions for fping and what should be the right permission?
          i am a noob in terms of Linux n Zabbix so apologies if i am asking stupid questions.
            Its all there in that Documentation page, if you care to read. If it is a orc language to you, then you maybe should try to read a bit more about linux file permissions etc. Its all available out there, in internet.
              • Mar 2022
              really damm how did i miss that.
              thank you
