Zabix agent 2.4.7 prooblem
  • PaulSz
    • Dec 2015
    Hi I am new to Zabbix. We just upgraded agent to version 2.4.7 and we continue to get the following error:
    cannot send list of active checks to
    8530:20151218:105814.571 cannot send list of active checks to [10.1.200.6]: host [Revolver-6] not found
    When I do:
    "cat /etc/zabbix/zabbix_agentd.conf |grep Hostname="
    # Hostname=
    Hostname=Revolver-6
    So, it should resolve the IP to host?
    Is this a bug? I also added the proper entries to a host file.
    Thank you
    Paul
  • ingus.vilnis
    • Mar 2014
    • 908
    Hi Paul,
    This means that you don't have a hosts with exact Host name Revolver-6 added in Configuration -> Hosts.
    Once added, this message should disappear from your Zabbix server log.
    Best Regards,
    Ingus
    • PaulSz
      • Dec 2015
      Thank you this fixed the problem. However, I do have the issue with Windows servers. The agent on Win 2008 server is configured with the exact server name as in Zabbix but I still get this error. Should I configured with the FQDN, but this would not make sense? Once again thanks for your help.
      Paul
      • ingus.vilnis
        • Mar 2014
        • 908
        Hi Paul,
        You should see the Windows hostname being used in zabbix_server.log as you already did with the Linux agent.
        Have you set the "Hostname=" setting manually in agent configuration or is Zabbix obtaining automatically "# Hostname=" setting is commented?
        Also the host names are case sensitive, so make sure they match exactly.
        Best Regards,
        Ingus
