Triger prototype update....
  • Alfista
    • Mar 2017
    • 136
    I have Isilon storage and monitor it over templates downloaded from zabbix templates repository. until now all works fine.
    Now we have added a newest isilon storage and I have problems on some nodes with Bad Disk triger.
    {HOST.NAME} - Bad Disk {#SNMPINDEX}         find(/Template SNMP EMC Isilon Node/diskDeviceStatus.[{#SNMPINDEX}],,"regexp","HEALTHY")=0
    The problem is that some disks in bay 1 and 2 are marked as L3 (they status too) while they are SSDs for L3 cache.
    Please can anyone help me how to change this triger that its doesnt recognise the SSDs as bad until they status change?
    I have now all running under Zabbix 5.4.7.
    Thanks.
  • Answer selected by Alfista at 17-03-2022, 14:01.
    Alfista
    • Mar 2017
    • 136
    I have tried to edit it to this:
     (find(/Template SNMP EMC Isilon Node/diskDeviceStatus.[{#SNMPINDEX}],,"regexp","HEALTHY") or find(/Template SNMP EMC Isilon Node/diskDeviceStatus.[{#SNMPINDEX}],,"regexp","L3"))=0
    but it will not work.
    Please can anyone help me?
    Thanks.
    • Alfista
      • Mar 2017
      • 136
      Thanks.
      • Alfista
        • Mar 2017
        • 136
        Its working, only there was some problems how it taked from zabbix to add to items the LLD triger.
        • ndrius
          • Dec 2021
          Alfista​, Could you please share a link from where I can also download zabbix template for Isilon OneFS monitoring? Thank you
          • Alfista
            • Mar 2017
            • 136
            I have downloaded from your Template site. And it was downloaded about year ago.Now it looks fully other and you have it on GitHub.
            • ndrius
              • Dec 2021
              I think you are talking about this one: https://github.com/zabbix/community-...onefs_snmp/6.0
              I have downloaded it, but i can find only "SNMP EMC Isilon Cluster" part and not "SNMP EMC Isilon Node". Because in template no any discovery items for disks or temp sensors.
              Maybe it's wrong template.
              • Alfista
                • Mar 2017
                • 136
                When I downloaded it, there wa s two templates:
                - 1. as a cluster
                - 2. as a node
                I have attached that I use, but I have tried to do a some changes to repair the problem but it doesnt work very good.
                I dont have now any problemetatic disks to test it.
                • ndrius
                  • Dec 2021
                  Thank you very much for help
                  • Alfista
                    • Mar 2017
                    • 136
                    Hope it helps to find the problem :-)
