How to upgrade 5.4 to 6.0
  • yatta
    • Feb 2022
    • 82
    I installed Zabbix 5.4 to Suse and now trying to upgrade 6.0
    But I couldn't find any documentation for Suse.
    https://www.zabbix.com/documentation...lation/upgrade
    All other sites referring that I can upgrade with "dpkg or yum" command but surely it's not exist on Suse. Only zypper and rpm.
    Any idea how can I upgrade Zabbix on Suse?
    Regards.
  • LenR
    • Sep 2009
    • 1011
    Do these directions work for package install? https://www.zabbix.com/documentation..._packages/suse
      • 4993
      OP probably refers to the fact, that "installation" pages have SuSE instructions, but "upgrade" pages have only redhat/centos and ubuntu...
      I never used SuSE but it seems that if you have repos available, then "zypper install" will upgrade or install if not yet installed...So follow installation manual..
      https://en.opensuse.org/images/1/17/...at-sheet-1.pdf
