Hi all,
trying to monitor an LSI RAID controller on Linux with this project: https://github.com/Art3mK/Zabbix-LSI-RAID-Monitoring . Opted for this project as an SNMP agent for Debian does not seem to exist.
The project seems to be geared towards Zabbix 3 and older. They instruct to first import a value mapping xml file ( https://raw.githubusercontent.com/Ar..._valuemaps.xml ), which it seems is not possible in Zabbix 5. I tried to resolve this by defining these value mappings manually at the level of the monitored host, but while importing the template ( https://raw.githubusercontent.com/Ar...D_template.xml ) I get:
Cannot find value map "LSI RAID BBU & LD Status" used for item prototype "BBU state on adapter:{#ADAPTER_ID}" of discovery rule "RAID discovery bbu" on "Template LSI RAID".
How can I circumvent this? I know the value mappings XML file can be imported in a template, but I cannot import the template without the value mappings. Seems like a chicken and egg dilemma.
Thanks!
BC
Thanks!
BC
