Zabbix Availability
  • rewilliamscpro
    • Dec 2015
    Zabbix Availability
    Hello, I am new to monitoring zabbix and can not find any documentation on this. When looking under configuration / hosts . My availability appears blue? Usually this is green. Does anyone know what this mean?
  • ingus.vilnis
    • Mar 2014
    • 908
    Hello and welcome to Zabbix forums!
    Blue icon is used in the dark frontend interface themes and means the same thing as the green one. It is only a visual representation. If you change the theme under your Profile section to any of the light ones then you'll should see green icons.
    Best Regards,
    Ingus
