Zabbix Dashboards - Graph Axis Values
  • lennys26
    • Mar 2022
    I have created a dashboard with graphs (not type: “graphs (classic)”, and my Y axis is behaving silly and setting values using decimal points instead of 'full' numbers.
    Click image for larger version  Name:	decimal.png Views:	0 Size:	16.9 KB ID:	441285
    I am using the following for the config of the Axis:
    Click image for larger version  Name:	decimal 2.png Views:	0 Size:	15.5 KB ID:	441286
    Although adding a MAX value for the axis will resolve the issue, I do not have a valid value to add there, so cant use that workaround. Also, curiously, adding a 'Graph (classic)' does present correct axes, but those graphs are much less pretty.
    Is there a way to adjust the intervals of the Y axis and/or force the Y axis to not use decimals and only use full numbers? (
    I am running 4.4.10.
    Thanks.
