I'm trying to install newest alhpa of zabbix in my lab, but with no success so far. Configuring source ends with error: database library not found (where databse is MySQL or PostgreSQL ). A liitle earlier there is warning:
checking for the linux kernel version... unknown family (3.10.0-123.el7.x86_64).
Earllier versions, which have been installed from packages, works fine, so I'm not sure, which libraries may be missing.
Have any of you manage to install this alpha version on Centos 7 or have similar problem and solved it?
Thank in advance.
Jacek
Thank in advance.
Jacek
