Proxy Zabbix No alert offline
  • slemoal
    • Nov 2021
    I monitor my different clients using zabbix proxies.
    My concern is that if the internet is no longer present, or if the server where zabbix proxy is installed is turned off, I have no alert informing me.
    Is it possible to make a trigger based on the last data received from the proxy? or another method.
    Merci
    Version française
    Bonjour,
    Je monitor mes differents clients grace à des proxy zabbix.
    Mon soucis est que si internet n'est plus present, ou si le serveur ou est installé zabbix proxy est eteind, je n'ai aucune alerte me l'informant.
    Est il possible de faire un declenchement basé sur les dernieres données reçu du proxy? ou une autre methode.
  • slemoal
    • Nov 2021
    all proxies are in active mode
      • 4906
      Internal items might help you.
      zabbix[proxy,<name>,<param>]
      Information about Zabbix proxy. Integer. name: proxy name
      Valid values for param are:
      lastaccess - timestamp of last heart beat message received from proxy
      delay - how long collected values are unsent, calculated as "proxy delay" (difference between the current proxy time and the timestamp of the oldest unsent value on proxy) + ("current server time" - "proxy lastaccess")
      Example:
      => zabbix[proxy,"Germany",lastaccess]
      fuzzytime() function can be used to check availability of proxies.
      This item is always processed by Zabbix server regardless of host location (on server or proxy).
      • slemoal
        • Nov 2021
        Thank you very much, it works perfectly
        Config item:
        Config function:
